paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
those bump pads arent going to holdup well
Yep, the motor takes up the passenger area[emoji41]Cannon gonna ride in that seat on the roof?!![]()
I'll leave the back glass open so we can communicate[emoji90]That's OK I will have a birds eye view of the crash
Lol, thanks....I'm 41 myself, so I'm not quite as grown up as you...[emoji481]Incredible vision, incredible skill. When I grow up (I'm almost 48 so keep that in mind) I want to be you. Great build. I love a good Comanche!
Oh shut up you web wheeler. Go back to Facespace and GQ.Just a ? Is the torque not multiplied on the sway bar the further away from the axle? If so you might need a bigger shaft to compensate
Don't get mad because your shaft may be inadequate I will still let you put on an apron and cook for me
Just a ? Is the torque not multiplied on the sway bar the further away from the axle? My dick is as small as a babies finger so i might need a bigger shaft to compensate
Yes you are correct. But at the same time I have shortened the arms by 7 inches (changing their motion ratio to nearly the same as the trailing arms/ shocks), thereby increasing the amount of work the levers must do in a shorter range of motion; virtually increasing the rate of the bar. Time will tell, I may have to change bar diameter...we shall see.Just a ? Is the torque not multiplied on the sway bar the further away from the axle? If so you might need a bigger shaft to compensate
stop picking on the little people lol@Paul, @loose cannon...
You guys with your shafts and shortcocks....I mean short cake...[emoji28]
Matt
... you might need a bigger shaft to compensate
It really depends on how you define perfect, which is intrinsically an opinion.You know, it's going to be a shame to have a less-than-perfect body on this masterpiece. You really have incredible talent. I mean the kind of stuff you see going to SEMA, but much more articulate engineering and execution.
It'd be so killer if Dan Short with DRS Automotive Fantomworks caught wind of this thread and wanted to team up for an over-the-top SEMA project. Crew it...I've emailed him before and had conversation with him....I'll give it another shot!
