And so it begins....
Snappy this thing is super pimp. Marsfab is doing some awesome work. I know you are looking forward to getting behind the wheel.
Yeah I had the wife drive the Excurison around the yard at mom and dads with me sitting in the drivers seat making the motor noises..... I got most of the stuff off to get paint on it at the end of the week.
Wow, just WOW!!!! Awesome job Chris but I did not expect no less...Looks really good!!!
I know you are a Happy Snappy!!!! lol Good luck racing, looks good Snappy and glad you finally got to a real close finishing point!!
Looks badass! Snap, you have to be happy with this thing.
Billy came over last night and we ruff plumbed everything. I still have to tighten everything and mount the lines but its ready to get fluids after its painted.
The spacers are used so I didn't have to buy a custom tc. This motor was never paired with a 700. The 2.8 is either exteranlly balanced or no the 3800sc is the oppsite so I cannot use the other fly wheel. This seemed to be the simpliest solution and I can have a new converter the next day if needed rather than waiting for one to be built.
Got about 5 hours in today. It doesn't look like much but all the front lights and fan are wired, the battery box mounted, master killswitch, and 1/0 run to the switch. Also got the right size belt and the coil pack mounted....
Snappy is good with wiring shit.
Got my gears setup and drive shafts down today at Oliver's in Winston. If you need anything go see Dave....and then the blow out on the way home.
Thanks to JC and Joe.....
We got alot done. Swaped out lower links, changed out all link bolts, got rear shocks mount with resi, mount and plumbed fuel cell and quart crate, got p/s and tranny cooler fans wired, 95% of the wiring done, fuel pump wired, coil packs mounted...also got the shifter mounted, offset joints in the drive shafts.
Man it's looking good slappy! That front driveshaft is awfully steep at ride height. I wonder if we could mount that pillow bearing frenched into the crossmember to help the angle a little?
