this is a great thread, I may be moving away from cherokeeforum.com. Nice build, I pm'd you a few questions if you dont mind.
did a tune up, plugs, wires, dist cap, etc.. made some bump stop steel stops.. gonna flex it out tomorow in rti ramp to see what is correct size shocks I need to order.So, gave up on using the doors, huh.
this was fastest route to get ready for racing
are you going to leave the PS cooler U-bolts pointing down? I've I'm seeing that correctly, they will be sheared off at the first rock you encounter. Can you rotate those brackets 90 degrees, mount them inside the front crossmember?
man thats one good looking jeep, you thought about making a rear set of doors? IMO it would finish it off and make it perfect.
sweet build!!![]()
