or Jenifer Lawrence nudezz
You need a link for those?
Shut up Ben. You knew what I was trying to sayHe will if he cant figure out how to spell her name.
Dont let @shawn see your links as I dont see plug welds and he will loose his shit.
can you emphaize on this a little about spring rate. I did my research on cutting a 6.5" spring down to the measurement for 3.75-4.25" of lift but didn't really comprehend the spring rate change...sorry there is sooo much info going on right now I'm trying to focus on so much but forcing myself to not get caught up on just one thing and keep pressing forward slowly of course not rushing. thanksWhile I agree with your point of teaching him right and wrong. I also feel he will be perfectly fine in this situation and may actually benefit from the increased spring rate. His cage probably weighs 1000lbs, he could use some extra spring rate...
That said, I hope he didn't just cut out 2" of coil expecting it to lower the ride height 2"
i agree but it's been stated already for just a crawler, I can get by with 0 and let the pinion be the more focal point rather than caster. At least its not tilted forward couple degrees anymore and once I make the driveshaft for it soon, I will be able to at minimum probably go a hair back as I cycle suspension when upper link is done and driveshaft is installed. right now looks like I should clear the driveshaft at full droop no problem without binding the axle end joint and that's my focus.Caster should be positive, which means the knuckle is leaned back at the top. Try for at least 3*. Caster is also relative to the ground, so the vehicle should be at ride height before you actually set it for good.
Spring rate isn't just a "hard and fast" number for any given coil. It is dependent on wire diameter, outside diameter, and active coils. If you remove some of the coils, the obvious effect is that you'll reduce the length of the spring, thus reducing the height of the vehicle. The inherent issue (good/bad/indifferent - you decide) is that there is an increase in spring rate.can you emphaize on this a little about spring rate. I did my research on cutting a 6.5" spring down to the measurement for 3.75-4.25" of lift but didn't really comprehend the spring rate change...sorry there is sooo much info going on right now I'm trying to focus on so much but forcing myself to not get caught up on just one thing and keep pressing forward slowly of course not rushing. thanks
so for the extra added weight of rig as someone stated, this can be a good thing?thus increasing the effective spring rate.
Spring rate is how stiff the spring is, or how resistant it is to change in height per force applied to the spring. F=-kx, where F is force applied, k is spring rate, and x is distance changed with force applied. With the direct relationship, the increased spring rate results in a higher force needed (added weight) to move the spring the same distance. So yes, the increased spring rate can be a good thing with the added weight.so for the extra added weight of rig as someone stated, this can be a good thing?
spring rate is how stiff/loose the spring moves up and down and how fast it does that?
... the vehicle should be at ride height ...
Well it's definitely changed the height which it should have according to how I measured. It's about 3" shorter lift already. Started out at almost 7" so big change now and it's almost got the whole weight on it without the body being off the Jack's so I'm happy with the outcomeSpring rate is how stiff the spring is, or how resistant it is to change in height per force applied to the spring. F=-kx, where F is force applied, k is spring rate, and x is distance changed with force applied. With the direct relationship, the increased spring rate results in a higher force needed (added weight) to move the spring the same distance. So yes, the increased spring rate can be a good thing with the added weight.
How fast it does so is controlled by your shocks. An increased spring rate will not control how fast it moves, only it's resistance to the change.
use limit, straps to control droop, not your shock length. Ive found that a center limit strap works better than one at each corner, as it controls center droop at high speed a bit better. also keeps the tires from grabbing and tearing it out. a coil sprung front will want to unload hard on a hillclimb too, so you dont want it dropping away like crazy. but a center strap at the right length will still allow for crazy flex
To calculate the radius arm correctly in a 3link calculator, you need to place the frame side upper mounting point at the same location as the frame side lower moiunting point.dang been off track lately, family visiting and other work to do. made little progress though
been playing with this link calculator and after several hours on it, I'm no further along than when I started WTH lol
I'm usually pretty good at math but this calculator puts wording in such weird terms..I've done researched so much already but most of what I'm reading is just more jiberish ...
so I don't know but I've figured this out:
my lower links are very good according to pretty much all lower link related topics/discussions and several different data sheets I've looked at I.E: they are very level to the ground, good length ...
34.75" center to center at frame end seperation lower link
41.6" center to center at axle end seperation lower link
distance from ground to frame side lower link is 22"
distance from ground to axle end link is 18.5" so this is pretty good and level from what I've been reading up
lower links measure 38.5 center to center
upper link will come off lower link on passenger side and measure roughly 27.9 center to center (chose this rather than driver side to not interfere with track bar and draglink that will be in that area and passenger side is free and clear)
my caster is back to 0 rather than -2 also and pinion is perfect where it sits currently so I'm happy with it so far.
this is what I've got so far but I'm frustrated with trying to use the computer to give me a upper link measurement so I just chose the 27.9" as it appears to be about what I've read is a good percentage of the lower that people recommend on 3 link radius setup...
thoughts/input is welcome but can't promise anything lol, I'm overloaded
I would suggest capping the back of that upper mount. I can see them twisting how they are currently. Put a plate between the two, behind the joint, that also tires back into the lower across the top.
