rockcity
everyday is a chance to get better
- Apr 10, 2005
- Greenville, NC
Been working on sheet metal the past day or 2 plus a few other little odds and ends...
The hood is narrowed about 6" or so, 3" off the back and 3" off of the sides. The height of the hood allows good enough room for my intake, thankfully. I was worried I wasn't going to fit the filter anywhere. The grill is the remnants of a stainless one I drew up and had cut for my old front end. I ended up modifying it to fit my new tube work in the front. Cowl area is all aluminum and finished up. interior sheet metal is mostly done except floorboard for passenger and rear firewall. Waiting on a few more brackets and tabs to show up so I can get those mounted before I tear down for paint
engine, trans, TC are all in there and mounted up. F body oil pan is in there. Boy was that a PITA. Had to take the windage tray on, off, on, off, more than several times to modify it and get it to fit. Then, the motor mount support I fabricated to go under the oil pan to help support the front of the skid plate was in the way for the F body oil pan, so I had to cut that off and re-do that... Seems like there is always something.
Anyway, its coming along.
i don't believe it... your buggy is FINALLY out of the garage!!!
