Had an extra hood and grill laying around and I needed an awning over shop door.
I bet the new neighbors love it!
Should add in some flood lights in the headlight bezels
Finally got my deck stained!View attachment 220742View attachment 220743
Sent from my HTC6535LVW using Tapatalk
I brushed all of the verticle surfaces and used a stain pad on the deck. I hate staining. This one was worse because I used a cheap deck cleaner that fuzzed up the wood and turned it white. Had to sand the whole SOB.Always interested to hear how ppl do theirs. Brush, roll, spray?
Curious as to what cleaner you used.... So I don't use itI brushed all of the verticle surfaces and used a stain pad on the deck. I hate staining. This one was worse because I used a cheap deck cleaner that fuzzed up the wood and turned it white. Had to sand the whole SOB.
I'm getting soooo pissed off at the guy who owned the house before us.
Lol..... I know your pain. Except my issue is with the builder and contractors. Tearing out to do a kitchen remodel and you can see where corners were cut. A lot of things wouldn't have taken but a minute or two more to do it right....
Yeah but that minute or two cuts into beer time.A lot of things wouldn't have taken but a minute or two more to do it right....
Fawk all that, I'd just have pounded the anchors a little more in and covered w/ spackle and repainted over them.Went to put up the new cellular shades in the kitchen last night, 3 windows next to each other over the sink. Took the old shitty vinyl blinds off of their brackets, removed the bracket screws from the sides of the window opening. There were 4 drywall anchors behind each bracket, with only 2 screws used per bracket. No drywall anchors were necessary at all, because there's a stud behind the drywall.
I then removed all 24 blue plastic drywall anchors (3 windows, 2 brackets each, 4 anchors per bracket), cut out a small section of drywall that was destroyed while originally installing the anchors (and was then painted over), and patched that section with setting-type joint compound. I don't have matching paint, so it's going to get sanded and primed and stay that way until we eventually paint that room.
Can you walk straight on to the door? Grill looks to be hanging below the door line.Had an extra hood and grill laying around and I needed an awning over shop door.
You do realize 26 years ago nailing sheetrock was a common practice. Your holding a 30 year old house to the same building practices as today.Yes, that's the story of much of our house as well; we found out ours was the last house in the neighborhood and sold partially-finished because the developer ran out of money. The previous owner must have hired the lowest bidder to complete the rest of the work. The other bullshit that the previous owner did is just icing on the cake.
It's just lovely crap like securing each sheet of drywall to the studs with a few screws, then filling the rest of the sheet field with nails. So we have nail pops that wouldn't exist if they completed things the rest of the way with screws. And they stopped after the second coat of joint compound, so all the joints and edges are slightly raised and not faired completely. I've been going through and adding that 3rd coat around the windows and corners before priming and painting in each room.
There's a laundry list of stuff like that. Someday, after a slightly obscene amount of time and money, this house will be cool. I'm undoing all the bad shit and completing everything like it should have been done 26 years ago.
We're planning on adding a 600-800 sf addition within the next year or so. Gonna try saving some money by doing a lot of the work myself, but what I sub out will be scrutinized with a fine tooth comb... Im in the same boat as you, house was built in 89 and most if not all the drywall is nailed. Our house had some serious moisture issues due to A leak in the bathroom. I've noticed most of the drywall that I've pulled down the nails were badly rusted, which makes me wonder if it's going to be a problem in the future.....
