Pimpin ain’t easy.Traded it for a golf cart. [emoji26]![]()
It has one more ride planned then a Dana 44 is getting swapped in.
That's not much of an upgrade....
Bigger/stronger housing than the D30, 30 spline RCV's are quite a bit stronger than D30 chromo's, bigger brakes, plus a marginal gain in R&P strength. It'll last until I transition to a 60/14 bolt.
Save your money and go from 30 to tons you’ll end up saving a ton of money
Already have the 44 and it didn't cost me anything but time, and it's bolt in.
Sell it to cover the cost of tons. A stock set of tons will last a lot longer than a built 44.
it's bolt in.
How many folks on here park their heap to "upgrade to tons" and then surf this forum INSTEAD of actually wheeling a functioning rig?
I'd rather spend time wheeling and break something than have something sit in a garage for months/years doing an upgrade that is so time consuming I can no longer wheel.
It's less about "building a tank that will wheel forever" and more about being able to wheel tomorrow.
I will at a later date just not right away, if I went straight for tons I'd have my rig down for awhile and blow a shit ton of money I don't really want to spend right now. Much rather wheel than tie up jackstands for months.
tie up jackstands for YEARS
@Noel is running a 44/9 on 42” PBR with no failures, walks all over everything with such good ground clearance. I’m running the same setup with 39.5s
Tons are better, yes, but that doesn’t mean the 44 is worthless. I wheel once a month or more and love the ground clearance with half ton axels. Will I go to tons one day? Maybe. Till then I’m still on the 44 ban wagon. Still an upgrade from a 30. Previous owner of my Jeep got lotsssss of good use out of mine and only broke a few axles, which have a lifetime warranty.
How heavy is that tin box YJ of yours with the tub split down the side?I believe weight to be the real killer.
