ghost
- May 25, 2006
- Hartsville/Camden,SC
Some of your toys would make clearing the acre I've been working on a lot easier....... The ole chainsaw and jeep will have to do since I'm broke.
What's engine and transmission is in that truck? What's the power output?
I saw in the other thread where you said it didn't have as much power as you expected. 71 seems pretty good for top speed as long as it holds it's own on the hills.
So I guess you have your CDL's now?Took the m916a1/M870a4 out for it's maiden voyage today. This is definitely the best setup I have driven. Rides great, 71mph top speed with the 52" tires.
425 is pretty good hp. Hopefully fuel filter will help like you stated. Maybe look for a boost leak also.
I got a farm tag (no CDL required). Plan to get used to it for the first year and then get the real commercial tag IF I decide I need it. Honestly most things I do with it will fall under the farm category anyways. Only bad thing is the 150 mile radius, but chances of me needing to go further are slim anyways.
Farm tag for this thing was about $850 (80,000), would be double that as a regular commercial tag. Bad thing is, with an 80k lb tag I can only haul about 33k. The truck and trailer scaled out at 46250 without chains, binders, etc.
I've been told by some of my farmer friends that farm trucks can run 90,000 these days as long as you don't get on an interstate. That might just be for commodities though.
If it has a actuator on the turbo it may need to be adjusted. Been a long time since a done one but it would start to open to soon and not reach full boost pressure. Also check for boost leaks in the intercooler system and intake manifold gaskets.Detroit 60 series (~425hp) Allison ht740. It should pull better than it does in my opinion, hopefully fuel filters will help.
Did you sell 2 of those trailers? I saw that one guy wanting to buy this one (again)
Have you tried to get any fuel economy #'s. I know it will suck, just curious.
Loading some stuff to take (for sale) to the military rally this weekend in Denton, knew the F350 would not make it up my driveway so I used the 8x8 to lift the tires and bring them down to the truck. I kind of figured the 8x8 wouldn't make it up the driveway either---it didn't. I backed it off the side of the driveway and left it for a drier day...
View attachment 267020 View attachment 267021
You must have a rough driveway if a 8x8 can’t make it up
