SHINTON
- Mar 17, 2005
- Triad area of NC
I guess the canvas will clip up somehow each time and then fold/go inside while going down the road? Getting all that watertight will be the biggest challenge.
so these are fully rebuild able and since the rims are 15" you can run just about any trailer tire.
WAIT! is that a subaru or vw pattern by chance??
I'm wanting to see the camper finished.
all that is left is to make door to cover hole when traveling and support bars to support bed when it is out.
are you converting the trailer to tag-along or just redoing the gooseneck?
right now I have a goal of Oct 9th to be done with it all..
I've got $10 that says your Dodge will still be two-tone on October the 10th.![]()
Now that is just pretty damn COOL! Door/hatch would hinge right onto the wood at the top, right?well I had to modify the support bar, then I washed the old canvas(still needs more washing) and then got it up and tested it to see how it will fit..
It is not perfect but to me it is not worth the money to have it cut down to fit perfect.. maybe down the road if it works out good in the long run.
Here it is looking from front to the back
Looking form the back
Do not mind the dark area that was still wet from me washing it.
another angle to show space from inside.
next is to work on door that will cover the hole when slide is pushed in
