wow....that truck is tall. I would've kept the boggers and lowered it. You're soon going to find out how bad the 49" irocs bring the suck.
Jeff, I think you have a knack for sounding like a dick when you dont intend to....just sayin.
FYI, I dont think George intends to wheel the "Toyota Monster Truck" so, actually the 49's will bring exactly what they need to..the chicks!!!![]()
mounting those us can be tricky with the 3 piece design...
First, if you are planning to run inserts, itll take you ~6 months from Stazworks or youll haveto build your own...
Also, i recommend using RTV/silicone on the orings, it holds them in place.... We put a set together this way that has been holding 10lbs of air for over a year...
They are heavy. Not really sure how I will get them bolted to the axle once the tires are installed?I bet it's a work out movin those suckers around the shop.
