'85 Xtra Cab Build
A little facelift...
When are you gonna finish the sweet paint?
Got back to work on the 4 link...truss mostly done. Still needs plate and go fast holes. Cuz that's what makes toyotas fast right?
Body: Primer - White Rustoleum Professional Sandable Primer
Paint - Gloss White Rustoleum Automotive
Tube: Primer - RUST and roughed it up with sand paper
Paint - Gloss Black Rustoleum Automotive
One more piece to the puzzle....
Yay. This should be cool. 14" 2.0?
Is your shock hoop oriented so that the shock has to be mounted on the top of the axle? If you can't fit it vertically, or you need that much up-travel, you could rotate your axle-end shock mount so that it's on the back side of the axle, to get it a few inches lower.
If it won't work off the top or behind the axle I can always shorten the wheelbase an inch or so to make it work off the back of the axle tube. It's really going to come down to cutting everything out from under the truck and going from there. I've got some ideas for the shock mounts depending on how everything lines up.
This weekend either Mtn City or Harlan will be the last weekend on the Toy axles and 38's. Going tomorrow to pick up my tires...
Chevy 60
14 Bolt
Sky Mfg Full Width Kit
42" TSL's
Chevy 60
14 Bolt
42" TSL's
SAAAAWEEEEET. nuttin liek a full width yota
Got the tires home...looks like one of them tire gnomes made its way back too...
haha! that needs to be robs new profile pic.
what wheels will you be running since you are getting tons and need new wheels?
bring it to harlan chris.
campsites 1-2-3 behind dairy hut.
should be a light weekend as far as crowds go.
we need to see it run can opener and lions den on toy axles
one more time.
don't worry barney & dawg will be there-- beating, scraping,
grinding, banging our way thru too. wish we had a gopro.
fun times.
dawg
Bald TSLs, never seen a set of those before. Lol where the tons at? I will bring that yoke up this weekend.
