A few updates:
My wife (i mean Santa) got me some Autometer gauges for Christmas... I'll be running a Tach, Oil, Water, and Voltage.
Holes cut in the dash for the column (not bolted in in the picture)... the heat controls will control 2-3 vents in the dash. Since the flat dash covers the defrost ports, this will be converted into heat that blows on the passenger and driver. I ordered 2.5" round vents... more to come shortly.
I painted the dash with the same color Rustoleum, but rolled (insted of spray) on 4 coats with some wet-sanding in between each. Looks pretty good in person. This is how I'll do the hood and cowl as well.
I also just ordered a Comp 6+ switch panel from 12voltguy. This panel uses an integrated fuse block. I am going this route rather than a pre-terminated fuse block. I'll use a small block for random things that arent on the switch panel (turn signals, brake switch, etc)
Also started welding an "orb of traction"
ummm yeah it is hot
Just received my wheel centers from GLO... still waiting on the rings.
