marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
btw...progress on RV is at a HALT...installed all the light fixtures and outlets and everything plugged back in and NOTHING.
The worst thing that could've happened did...me screw up something electrical (I guess I did). All worked before the teardown, now nothing. The outlets I quickly found breakers were down from where I was moving it around must have hit them down but all the interior lights no power, fuses good under dash, fuse in breaker box for "lights" good so after hour and a half of piddling with it, I quit (too much stress).
From what I've read/been told: interior lights are 12v DC (run on car batteries) until plugged into power then runs from the inverter thing. BUT it's all wired like house current/wires which I don't know for the life of me and there are black/white mostly to the lights...2-3lights have white & green wires....some have yellow & black & green & white???????????????????????WTH WTH WTH
I plugged up all the wires back to their "color coded" selves except the ones I know/thought aren't being used anymore and now no power to nothing.
The only for sure wires I know are the white wires are ground cause i followed 2 back to the ground strap bolted to frame behind power box. 1 black wire coming from power box labeled "lights" and 1 Big Green wire on seperate breaker labeled "oven fan & lights). I left that capped off since I didn't use a oven fan but that thick green wire is spliced in with couple of the ceiling lights around that area to the black wire...I'm so lost.
I'M sorry if this confuses the heck out everyone but it's the best way to describe what is wired there. PLEASE bare with me if you attempt to explain this home wiring stuff as I have always had a hard time understanding so many colored wires no matter how much I've been taught. Thank you, any help would be great!
