ol'Jeeps
Dirty Jeeps...Done Dirt Cheap!
- Dec 5, 2006
- Hickory, NC
I expect to strap the droop at 19-20". At ride height I have 9.5" up. Wouldn't be upset at all with 18-20". Without going through the measurements, I'm sure the shaft will operate properly with. +/- 19".how are you gonna deal with the driveshaft bind and all that travel? with your motor moved back so far will you actually get that much travel when driveshaft is on?
I had a ton of travel until I installed the driveshaft and then I had to put limit straps on due to binding
see images of my jeep:
http://www.impaks.com/images/ken/wrangler/img_5091.jpg
http://www.impaks.com/images/ken/wrangler/img_5095.jpg
http://www.impaks.com/images/ken/wrangler/img_5096.jpg
That's BADASS!
Daytime should be great, I think we have a chicken stew to go to in the evening.Yo Matt, might cruise up to Mayberry on 10-29 and check dis pig out again. Work for u?
These particular are not made any longer. I haven't run these, but @ChrisAyers has for some time on a cherokee.I've been researching beadlock wheels again. I enjoy my H1's just not the ride at speed instead of crawling. Are these Pro Comp beadlocks still available? Have you run them before?
I've been running them for 2 years now and I love them, haven't had any leak down whatsoever. As far as I know, they're only available in a racer program or used like Cutler and me got ours. I've only seen them in 5 and 6 lug and in a 17" with hardly any offset.I've been researching beadlock wheels again. I enjoy my H1's just not the ride at speed instead of crawling. Are these Pro Comp beadlocks still available? Have you run them before?
for helping on the cage. I can honestly say I can put Ray Charles best welds to shame.
There really needs to be a drool emoj. Words do not begin to describe this build.
I've resisted putting Chris's Cherokee on blocks just to see what those wheels would look like under the Zuk.
By the way I owe you a few [emoji481] for helping on the cage. I can honestly say I can put Ray Charles best welds to shame.
Can't wait to see this beast on the trails.
Thanks for the info. I'm looking at options for some things on my next rig. So why coilovers up front with air bumps instead of ORI's? With the tight space in an MJ/XJ ORI's seem to be the best answer. Am I wrong on that or are there other reasons for the coilovers? Also are the leaned in and back? Why?I've been running them for 2 years now and I love them, haven't had any leak down whatsoever. As far as I know, they're only available in a racer program or used like Cutler and me got ours. I've only seen them in 5 and 6 lug and in a 17" with hardly any offset.
